1999 new shape V6
Bainsy
1999 new shape V6
Post by Bainsy » Sun Mar 11, 2012 11:01 pm
Only had my Bongo for a week and realise I need to check ATF level under drivers seat. Is this the same process as lifting passenger seat? Thanks for any advice.
Nigel
New Shape White over Silver V6 LPG JAL Side Conversion Mushroom Roof
Bongoplod
Re: 1999 new shape V6
Post by Bongoplod » Sun Mar 11, 2012 11:03 pm
If the seats are the same as on 2.5 diesel,yes,exactly the same for each side
Brian
westonwarrior
Post by westonwarrior » Sun Mar 11, 2012 11:08 pm
yes all seats are the same
Post by Bob » Sun Mar 11, 2012 11:33 pm
Mirror immage. :wink:
Post by haydn callow » Sun Mar 11, 2012 11:57 pm
If you have a rear side conversion you may not be able to tilt the seat back...if that's the case just remove the seat...4 x bolts...5 min job.
Bainsy
Post by Bainsy » Mon Mar 12, 2012 9:05 am
Tks for all the helpful replies. I do have a side conversion so will have to see if seat tilts back or has to be removed.
Nigel
apole
Post by apole » Mon Mar 12, 2012 5:24 pm
Hi there,
I had a V6 with side conversion. Found that you could tip the seat back enough to check the level, I used a small offcut of wood as a prop to ensure the seat didn't fall down on my head !! Simple and easy. Anything more like changing plugs/air filter I'd just remove the bolts and take the seat out. Just be careful not to scratch the paint with the metal runners.
When you check the ATF have the car on a flat surface and check it when the engine is warm with the engine running.
If you don't know the history it's worth getting all the fluids changed then going from there, quite a cheap job compared to replacing the box.
Andy
Bainsy
Post by Bainsy » Mon Mar 12, 2012 10:08 pm
Thanks for that Andy
Nigel
