I want to replace the gearbox gasket on my bongo as its dripping every where how to i drop the ATF out the gearbox cant find the bung?
draining the Gearbox sump 2.5 td bongo
MountainGoat
Re: draining the Gearbox sump 2.5 td bongo
Maybe this master class from Missfixit70 will help you.
Tony
http://www.igmaynard.co.uk/bongo/forum/ ... 96&start=0
Tony
fatcatlawyer
- Tribal Elder
There aint one! The ideal would be to remove the transmission fluid by means of a Pela pump, then undo the holding bolts so as repair/replace the gasket. In the absence of a Pelaa pump be prepared for a cascade of fluid as you undo the bolts.
the level of the fluid is above the gasket when it is up to the mark on the dipstick.
Ian G
Ian G
I've seen drain plugs on some 1999 models. Looking at the sump from the N/S side, it's on the N/S rear of the sump.
