Driver side window electrics.
Jacobus
Post by Jacobus » Tue Mar 06, 2012 6:12 pm
Ye God's I cannot believe it's been so long since I last asked a question :shock: but, the double switch controlling driver's front window no longer worked so have replaced it having first checked that it was not the electric motor that had died. Conclusion broken wire, not fuse cause passenger window worked even with dodgy switch. Question is there a harness replacement because the wiring where cables exit body into door looks decidedly dodgy, or am I going to have to do some work like making one to join into original system under dash. Things have been going so well. Chap in village turned up on holiday with a Bongo bought just before he left for Portugal, got a few hundred Kms into France and the engine blew...about £3,000 and a very unhappy wife. Nobody had warned him to keep an eye on the Temp. bought from a dealer not a private buy. Hope to persuade him to fit a Temp. warning system before he heads back to UK. cheers, Jacobus.
Re: Driver side window electrics.
Post by g8dhe » Tue Mar 06, 2012 10:54 pm
The normal on the harness is just to repair it, quite a few threads about the problem, Jaylee is probably best to speak to!
Post by Northern Bongolow » Wed Mar 07, 2012 4:38 am
contact a breaker,the harness concerned is only small from the door to just inside the body to a multi plug, so easy to swap out.
helen&tony
Post by helen&tony » Wed Mar 07, 2012 5:03 am
New harness:
CLUB SHOP
Jacobus
Post by Jacobus » Fri Mar 09, 2012 4:30 pm
Sorry about delay in answer :( got visitors but thanks for the info will have to make a choice but due to go to north Portugal next week so will probably wait till I get back....Thanks again, Jacobus. :D
Post by francophile1947 » Fri Mar 09, 2012 5:04 pm
It's probably just the thick black wire in the loom. I used a block connector as a "temporary" repair, but it's still there and working :oops: :lol:
