power management sytem
graham8299
Post by graham8299 » Mon Mar 05, 2012 4:34 pm
should i have heating working when hooked up? does anyone have instructions for power management system, i need help :shock: :shock:
nigelgibson
Re: power management sytem
Post by nigelgibson » Mon Mar 05, 2012 4:55 pm
What sort of heating are you referring to ?
The power management system or hook up have no heating capabilities so i am a little confused. #-o
If you try www.autocraftmotorcaravans.co.uk they sell zig systems and will probably post you a photocopy of instructions. They kindly gave me a copy when i bought a second hand unit off ebay [ i live locally to their base in chesterfield]
Post by g8dhe » Mon Mar 05, 2012 5:07 pm
Yup there are several types of power control systems, there are the PMS3 units;
then there are the ZIG's they range from Marque 1 thru to the ZIG9 all different!
And some of the Converters don't always use a standard system either....
But none do any sort of heating, oil filled mains powered heaters are popular, or LPG/Diesel heaters fitted to the van.
Return to “Scotland”
