Clicking noise
winchman
Clicking noise
Post by winchman » Thu Mar 01, 2012 6:29 pm
Only hear this when I drive with the window open but when I brake I get one metalic click?
Any ideas before I have a look at the weekend?
Its the drivers side
briwy
Re: Clicking noise
Post by briwy » Thu Mar 01, 2012 6:55 pm
Might be the anti roll bar bushes Dave.
Our old one did this, changed the bushes and it stopped.
winchman
Re: Clicking noise
Post by winchman » Thu Mar 01, 2012 7:02 pm
Thanks, can I tell by looking?
Re: Clicking noise
Post by francophile1947 » Thu Mar 01, 2012 7:11 pm
Sounds like the pads moving - maybe a shim missing/loose. It's not uncommon for the pads to move slightly in the callipers.
carlioll
Re: Clicking noise
Post by carlioll » Thu Mar 01, 2012 7:15 pm
Sounds like brake pads to me. Some of the cheaper pads on offer have locating lugs slightly too small causing the pads to flop about !!! Have you changed the padds recently?
mentaliss
Re: Clicking noise
Post by mentaliss » Thu Mar 01, 2012 7:19 pm
winchman wrote:Only hear this when I drive with the window open but when I brake I get one metalic click?
Drive alongside a wall apply the brake pedal on and off , does the clicking noise change? if so its your pads foating up and down the caliper pins as they should do!
M 80NGO
Re: Clicking noise
Post by M 80NGO » Thu Mar 01, 2012 10:57 pm
I remember this from a couple of months ago where another member had the same issue and it turned out that the wrong year pads had been fitted at some point that were slightly too small and were moving when the brakes were applied, i'd be fairly sure that this is your issue.
winchman
Re: Clicking noise
Post by winchman » Thu Mar 01, 2012 11:23 pm
carlioll wrote:Sounds like brake pads to me. Some of the cheaper pads on offer have locating lugs slightly too small causing the pads to flop about !!! Have you changed the padds recently?
No only had the Bongo a few weeks
