spare tyre
spare tyre
just purchased my first bongo, 95 model, it appears that the hook is seized on the spare tyre housing (it looks like it has never been used) as a result i effectively have no spare. any advise would be greatly appreciated.
Re: spare tyre
I can't even remember a hook
Does it wind down OK?
Re: spare tyre
no, whole thing is seized up.
- mikeWalsall
Re: spare tyre
Plenty of penetrating oil may free it ... but would you really use / trust a 17+ year old tyre anyway ..??
Re: spare tyre
It looks a very simple mechanism, can you not spray some WD40 down the winding hole and back up from underneath the tyre ?
http://lushprojects.com/bongopartsmk2/c ... o=.html#12
MountainGoat
Re: spare tyre
The spare wheel hangs on the end of a cable which has the hook attached to its end. It is just a simple wind up and down mechanism.
Tony
Tony
- Simon Jones
Re: spare tyre
The cable can be wound up either way, so try turning it clockwise in case the previous owner wound it up the wrong way.
Re: spare tyre
grind the end off the cable, once the wheels out of the way you can see whats going on etc.
Re: spare tyre
success! liberal spaying overnight with "wd40" & hey presto down she came. took the spare to a tyre shop who said it was ok & a good cleaning with "copper grease" & all is well. thanks to all who replied, much appreciated.
- dandywarhol
Re: spare tyre
Now go and find a full sized Bongo wheel and fit a new(er) tyre to it. In fact I might know a man who can
Re: spare tyre
cheers dandy, info please/
