Air flow meter V6
davidneeves
Air flow meter V6
hi i have a v6 bongo and i think the air flow meter may be faulty.is there any way of testing it before i go out and buy a new one because knowing my luck it could be something else that is causing the problem thanks Dave
Re: Air flow meter
what symptoms have you got?
Julian
Julian
davidneeves
Re: Air flow meter
thanks for the reply.the engine has lost a lot of power and will not rev above about 35000 i have changed the plugs/dizy cap/routerarm/ht leads and the air filter but with no improvement.there is no missfire and engine runs smoothly just got no power thanks Dave
- Simon Jones
Re: Air flow meter
Probably 'cos it's not a jet enginedavidneeves wrote:the engine has lost a lot of power and will not rev above about 35000
Does it rev freely when in neutral? Other thing to consider is tweaking the TPS as this can influence the point where the gears change.
Re: Air flow meter
Hi davidneeves,
It might be worthwhile changing the Fuel Filter and the Air Filter.
Cheers...
Cheers...
davidneeves
Re: Air flow meter
thanks chaps will try your suggestions
let you know how i get on
Re: Air flow meter
Dave, an update on a V6 that wouldnt rev past 3000 (less when warm) turned out to be a crank pick up sensor failing/failure, even tho the onboard diagnostic didnt actually see it?
Julian
Julian
Allans
Re: Air flow meter V6
That's interesting Julian. The diagnostics usually pick it up.
I had another V6 in recently that wouldn't rev above 3000. That was just faulty valve timing.
Bogmonster40
Reading all of the above reaffirms exactly how little I know about my little motor......
V6 2.5i Tintop Aero Petrol/LPG
