I have had a problem with my headlights. I start the engine, turn the headlights on then a couple of seconds the headlights go really dull, so dull you can't see the beam from in the cab. There is a rocker switch under the steering wheel which when turned off, the headlights are fine and bright all the time! Anyone know why there would be a switch that makes the headlights so dull after a few seconds? Asked the garage to check and for ideas when it went in for its MOT and they are stumped because the switch does seem to control anything else
. Any ideas?
Only thing I can think of is it is some sort of cloaking device
