Fuel pump
The 3Ts
Fuel pump
Post by The 3Ts » Fri Feb 17, 2012 9:10 pm
Hi all
i know this subject is an old one but i have replaced the o ring on the fuel pump the advance plunger.
taken off the dome the 2 springs and the metal cup at the end of the springs
which way round does the cup go ie cup towards the springs or towards the plunger i wonder if i have got it the right way around now i have got it back together.
Also wot is the best way to bleed the system once back together
Re: Fuel pump
Post by teenmal » Sat Feb 18, 2012 6:21 pm
Hi,this might help you
http://www.igmaynard.co.uk/bongo/forum/ ... am#p469087
The pump is usually self bleeding,but can be primed at the inlet on top of the pump.
