front and rear brake pads wanted
maxheadroom
Post by maxheadroom » Fri Feb 17, 2012 5:51 pm
anyone have any suggestions where to buy front and rear brake pads for a 95 diesel :D
Keep the Faith
westonwarrior
Re: front and rear brake pads wanted
Post by westonwarrior » Fri Feb 17, 2012 6:03 pm
club shop?
maxheadroom
Post by maxheadroom » Fri Feb 17, 2012 6:11 pm
I do use the club shop (head, water pump etc) but this time it's either £160 club shop or £88 from ebay for what I need :shock:
Keep the Faith
westonwarrior
Post by westonwarrior » Fri Feb 17, 2012 7:15 pm
I looked and 35 front and 35 rear so £70 for all 4 corners
maxheadroom
Post by maxheadroom » Fri Feb 17, 2012 7:41 pm
westonwarrior wrote:I looked and 35 front and 35 rear so £70 for all 4 corners
should of said I'm going to change rear discs too as they were an advisory on the last MOT
Keep the Faith
carlioll
Post by carlioll » Fri Feb 17, 2012 7:56 pm
Be careful buying cheapo ones on ebay. The lugs on some pads are slightly smaller than required causing the pads to flop around and cause annoying noises. I found this out to my cost recently. Also cheapo ones tend to cause a lot of brake dust messing up your alloys.
horus01
Post by horus01 » Fri Feb 17, 2012 7:58 pm
saw a full set of front and rear pads £44-ebay.Need to change front on mine so will do back at same time
Post by Northern Bongolow » Sat Feb 18, 2012 3:36 am
ebc brake pads get my vote mate, not too hard/soft and very low dust, and they fit without the clicking as stated above.
think kirsty has some part numbers if you need.
pm me if your struggling, you may need to ring her.
Post by teenmal » Sat Feb 18, 2012 11:51 am
Hi Max,
Found these people sell quality parts reasonably priced.
http://stores.ebay.co.uk/Nippon-Auto-Pa ... 34.c0.m322
MountainGoat
Post by MountainGoat » Sat Feb 18, 2012 12:01 pm
That's were I got mine from although I delt with the shop directly Deepvault Limited t?a Nippon Autoparts http://nipponautoparts.com, Meadow View Llanddewi, Llandrindod Wells, Powys. LD1 6SE. Rear Pads were allied Nippon asbestos free pads and Front Pads were Solid Ace asbestos free pads. Prices were similar.
Tony
maxheadroom
Post by maxheadroom » Sat Feb 18, 2012 3:42 pm
teenmal wrote:Hi Max,
Bought front for now and see what there like :D and thanks all for the advice =D>
Keep the Faith
