but**should there be air glugs coming up the big pipe at the bottom of the expantion tank
If so should we carry on untill the bubbles that go up into the expantion tank stop? I fear maybe we are not doing it for long enough.Iam not sure how long your ment to bleed for.
Iam using the seesaw method,allowing the stat to open at about 86 oc ,bottom hose geting really hot,heaters hot .he foamy bubbles that you 1st get in funnel clears and only a few slight bubbles coming into funnel,and the water is clear as a bell.(poss from water pump by the looks of the advise on vids).
Thanks chaps...may have to take it to the garage next week!
