Powering the TV
winchman
Powering the TV
Post by winchman » Mon Feb 06, 2012 11:00 pm
Whats peoples thought on this?
The TV is 12v but the Bongo electrical system can give out 14, so may damage the TV.
I have seen a regulators for sale but at £39 it seems a tad expensive, so do I really need this and is there an alternative?
Re: Powering the TV
Post by francophile1947 » Mon Feb 06, 2012 11:04 pm
I just plug mine into the cigar lighter socket and have never had a problem, even when the battery is being charged by my Lidl/Aldi charger. Never done it with the engine running though.
Re: Powering the TV
Post by haydn callow » Mon Feb 06, 2012 11:07 pm
probably o.k. up to 15 volts....but why would you want to use it with the engine running ???
winchman
Re: Powering the TV
Post by winchman » Tue Feb 07, 2012 12:27 am
haydn callow wrote:probably o.k. up to 15 volts....but why would you want to use it with the engine running ???
Kids can watch a DVD on the journey
winchman
Re: Powering the TV
Post by winchman » Tue Feb 07, 2012 12:34 am
Do you think they are required for LEDs?
My LED strip lights have 30 LEDs in them so would my maths be correct they are split in to 3 banks, so any over voltage would be shared over the 30 LEDs so shouldnt matter as its never going to hit 15v?
I was looking at these
http://www.reuk.co.uk/buy-12-VOLT-REGULATOR.htm
scanner
Re: Powering the TV
Post by scanner » Tue Feb 07, 2012 12:42 am
The answer is that some TVs are more tolerant of over voltage than others and there is really only one sure way of finding out how tolerant yours is.
http://www.caravanning4u.co.uk/forum/ar ... 20996.html
This guy found out the hard way..............
http://www.ybw.com/forums/showthread.php?t=135890
winchman
Re: Powering the TV
Post by winchman » Tue Feb 07, 2012 1:34 am
Must be a product to do this for less than £39?
scanner
Re: Powering the TV
Post by scanner » Tue Feb 07, 2012 10:21 am
Not reliably it would seem. The Amperor is pretty much the market leader.
dave_aber
Re: Powering the TV
Post by dave_aber » Tue Feb 07, 2012 10:27 am
winchman wrote:Do you think they are required for LEDs?
1 LED fed with 15v will see 15v. 1000 LEDs in parallel fed with 15v will all see 15v. Current is divided between each leg in a parallel circuit, voltage is common to all legs.
Image...Image
winchman
Re: Powering the TV
Post by winchman » Tue Feb 07, 2012 12:11 pm
scanner wrote:Not reliably it would seem. The Amperor is pretty much the market leader.
It looks to be the only opne available?
winchman
Re: Powering the TV
Post by winchman » Tue Feb 07, 2012 12:12 pm
Dodgey
Re: Powering the TV
Post by Dodgey » Tue Feb 07, 2012 8:07 pm
That post over on another forum about the guy plugging in a 12v TV and it going "plink" because his battery was at 13v is very suspicious. MUCH more likely he got the polarity the wrong way round. Most devices like 12V TVs have their own build in regulators. Even if they don't , the difference between 12v and 13v is marginal. It's more about current, and devices only draw the current they need.
All cars , as far as I've been aware, run at around 14v when the alternator is going, and yet, all car devices are sold as "12v".
Re: Powering the TV
Post by Simon Jones » Wed Feb 08, 2012 1:25 am
Many flat screen LED / LCD televisions run off 12v, but unless it came with a separate lead that plugs into the lighter socket (so is sold as suitable for car use), then I personally would not risk it. The TV will have some degree of regulation built in, but it is intended to connect to an external PSU that is designed to stabilise the voltage to much closer to the 12v level of the TV input.
The reason manufacturers of proper TVs intended for use in motorhomes such as Avtex are able to charge £50 to £100 more that Tesco or Morrisons is that they build in the correct regulation and smoothing circuitry to handle the range of voltages and interference found in a vehicle.
I face the same dilemma: I've got a brilliant 17" LCD TV for £90, but I'm going to continue to run it from the mains PSU until I either buy or make a suitable voltage regulator.
winchman
Re: Powering the TV
Post by winchman » Wed Feb 08, 2012 7:22 am
So how would you make one?
