Post
by pippin » Fri Jun 30, 2006 4:55 pm
OK, lift the carpet offside rear, locate the fuel sensor above the fuel tank - where there has been trouble with a poor earth connection.
Remove the entire fuel sensor assembly from the tank.
Obtain a piece of dowelling.
Plunge it down into the tank until it touches the bottom.
Remove the dowelling and visually inspect it.
You will notice a wet mark on it which indicates the depth of fuel in the tank.
No wet mark? It's EMPTY!
Oh, an automatic warning system?
Will work on it.
