Fitting Mazda 6 alloys 17" do they fit?
2manymadmonkeys
Post by 2manymadmonkeys » Sat Jan 28, 2012 12:02 pm
Hi has anyone fitted these to a bongo they are the same stud pattern are there any issues ?
dandywarhol
Re: Fitting Mazda 6 alloys 17" do they fit?
Post by dandywarhol » Sat Jan 28, 2012 12:30 pm
Bongo (unconverted) 30% heavier than Mazda 6 - will your insurers be happy?
2manymadmonkeys
Post by 2manymadmonkeys » Sat Jan 28, 2012 2:52 pm
I know I need load rated tyres 98+ but the alloys are ok ? I think there 600kg is each or is that not enought
dave_aber
Post by dave_aber » Sat Jan 28, 2012 7:34 pm
Let's see - Kerb weight 2350Kg.
Assuming best-case with 25% of the weight on each wheel evenly, then that's 588kg per wheel.
Of course, the weight distribution isn't going to be perfectly even, so 12kg isn't enough leeway.
That's before you chuck it into a corner....
As a guide, 98 rated tyres are good for 750Kg each, so 600 Kg rated wheels seem under-spec.
Image...Image
2manymadmonkeys
Post by 2manymadmonkeys » Sat Jan 28, 2012 7:57 pm
Keep clear of them then will have to look for wheels of 700 + thanks for advise
stuc
Post by stuc » Sat Jan 28, 2012 9:42 pm
What are RX8's out of interest. I take it these are ok?
2manymadmonkeys
Post by 2manymadmonkeys » Sat Jan 28, 2012 9:46 pm
They would be the same I guess ? Lots of people have them on bongos
mikeWalsall
Post by mikeWalsall » Sat Jan 28, 2012 9:55 pm
Maybe some with some expertise could post up a list of wheels that not only fit but are 'weight safe' ..
I recently bought some Lexus GS300 rims with the right PCD @ 5 x 114.3 (bolt holes / spacing) but the bore size @ 60.1mm was to small as the Bongo needs to be 67.1mm (or bigger and use spigot rings) ...
http://www.wheelfitment.net/mazda
I think you will find the OEM R6 rims are 16" ..
I must admit that I am still searching for 'rims that would fit' and have seen a few Bongos with Mazda R6 and R8 wheels fitted and assumed (not always a good thing to do then) that they where OK ...
The Great Pretender
Post by The Great Pretender » Sun Jan 29, 2012 2:00 am
The stress on a wheel involves a number of calculations regarding sprung/ unsprung weight just for starters.
If you think the cooling system is difficult....................... :lol: :lol: :lol:
To infinity and beyond
Windswept
Post by Windswept » Sun Jan 29, 2012 2:19 am
Hi there.
We have five-spoke plain-spoke alloys that were stated to be from a Mazda 3 - see this link
http://www.ebay.co.uk/itm/0129-x4-Like4 ... 4ab32a4ebf
They also do a Mazda 6 wheel - see this link
http://www.ebay.co.uk/itm/0167-x4-Like4 ... 4ab32a59e1
Ours have been on the Bongo for almost 4 years now, and we can both be described as "spirited" drivers :roll: on occasion. Never had a moment's problem with the wheels :) . We have slightly oversized tyres on (235/55/17) which brings the rolling radius up a few percent, i.e. makes the speedo closer to accurate, and gives a tiny bit more mpg :D The offset is only a few mm out from the Bongo, and we have not had any concern about wheel bearings.
I can be prone to a bit of uneccessary concern/ worry about this sort of question, but our experience here should help reduce the anxiety a little :)
However, it is your call.
Paul
Blue/Silver AFT, named TIKI, the Hawaiian God of fair winds & good fortune.
Plus a Quechua Base.
mikeWalsall
Post by mikeWalsall » Sun Jan 29, 2012 3:04 am
At the moment (2.0am 29/01/2011) if you do an eBay search for Mazda Bongo wheels ... there are 753 listed ..
I assume that some will be weight safe ... but which ..??
I also assume that Mazda at some stage offered genuine OEM Alloy rims .. who as any of those fitted ..??
I see lots of Bongos with alloy wheels ... surely someone knows there make .. load tolerances etc: .. ??
2manymadmonkeys
Post by 2manymadmonkeys » Sun Jan 29, 2012 6:40 am
I like these don't know if there any good emailed seller asking for ratings it says there for a bongo we will see
End time: 22 Feb 2012 11:23:17 GMT
iPhone URL:
17" TEAM DYNAMICS CYCLONE SILVER FOR MAZDA BONGO
Browser URL:
Look at this on eBay:
http://bit.ly/A7jVdZ
 Bens iPhone  
mikeWalsall
Post by mikeWalsall » Sun Jan 29, 2012 9:24 am
Price wise ... they are well out of my budget ..
Me personally .. I would sooner have a genuine car makers wheels .. obviously .. Mazda ... but Lexus .. Honda .. Hyundai ..etc; ..
This is one of the five Lexus GS300 that I bought and had refurbished for the Bongo ... with to small bore to fit the load bearing spigots on the hubs
This is a Lexus wheel on my Toyota Estima ... the set have been on for well over six years ... I have to admit that I never took any 'safe weight' into consideration ..at that time ..I liked the alloys ..and they fitted .. end of storey ..
I do have a list of compatible OEM wheels are far as PCD .. bore .. offset are concerned ... just never took there (unlisted) load bearing into consideration ...
dandywarhol
Post by dandywarhol » Sun Jan 29, 2012 3:37 pm
The Great Pretender wrote:The stress on a wheel involves a number of calculations regarding sprung/ unsprung weight just for starters.
Not to mention potholes, speed bumps etc........................
Have a look at some of the BMW fora to see how many problems they're having with lightweight wheels and low profiles.....................
stuc
Post by stuc » Sun Jan 29, 2012 10:33 pm
I think the BMW issue is more to do with a manufacturing defect than improper fitment and they will replace under warranty if there is a problem.
