Interesting post
Interesting post
Post by haydn callow » Thu Jan 26, 2012 7:33 pm
Saw this on the "other" forum....what do peeps think ??? non starter or worth a bit of research ??
I've been a bit of a lurker here so it's a bit bold to ask for advice! However;
Has anyone ever swapped an engine, or even heard of an engine swap for a Bongo? I dont mean swapping Bongo engines, but fitting a completely different engine...
After much chin scratching I've concluded that the standard Bongo engines are irredeemable; there's any number of improvements to be made to them but, fundamentally they'll never be fuel efficient. Not like a modern TDCi engine.
So if:
Bongo engine = Ford ranger engine and if the Ranger engine was replaced by Duratorq units later in its life then shouldnt it be possible to fit a reasonably modern ford unit into the Bongo? I would have thought that an automatic ZSD-422 would fit the bill.
£2000 for an engine and box, and, say £2500 to get it to fit, sell the old engine for £750, total cost £3750.
15k miles/year @ 22.5 mpg = 600 gallons, @ £6.5/gallon = £3900
15k miles/year @ 45 mpg = 300 gallons, @ £6.5/gallon = £1950
So the cost of the new engine would be repaid in less than 2 years.
It adds up, but I know almost nothing about the practicalities.
Any pointers before I get the engine hoist out?
Rhinoman
Re: Interesting post
Post by Rhinoman » Thu Jan 26, 2012 7:55 pm
I've been wondering about something like this myself. I think I would do something like this is I ever had a head go on my Bongo. The cost of repair v replacement with the benefits of a more modern engine makes it well worth considering. The downside is that there would be a lot of wiring to do to get a Di engine in and running which would put off a lot of people and then there is the possible issue of insuring it with a non-standard engine.
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
Post by rita » Thu Jan 26, 2012 8:11 pm
These engines are fitted to the Thailand-built 2007 Ford Ranger (J97U). the Land Rover Defender and some Transits etc etc,in various sizes,the only thing I would be concerned about is the MPG with a second hand engine.If you can afford it and you do the mileage it might be worth a punt.
briwy
Post by briwy » Thu Jan 26, 2012 9:58 pm
I would be very surprised if you got anywhere near 45mpg from a modern engine in a Bongo.
I regularly get about 48mpg from my 2.0 TDi Octavia Estate but the same engine in a VW seems to get around the 35 mark if you're lucky so overall I doubt if it would be worth the hassle.
Post by francophile1947 » Thu Jan 26, 2012 10:32 pm
briwy wrote:I would be very surprised if you got anywhere near 45mpg from a modern engine in a Bongo.
I doubt if many if us do 15000miles per year in the Bongo either.
Post by Bob » Thu Jan 26, 2012 11:05 pm
Don't think you would ever see your money on this, Bongo weight and aerodynamics come into play, and I really think this would turn out to be far more work than it first seems.
Post by haydn callow » Thu Jan 26, 2012 11:34 pm
Bob wrote:Don't think you would ever see your money on this, Bongo weight and aerodynamics come into play, and I really think this would turn out to be far more work than it first seems.
Thats was my first thoughts...and I still think the same
Post by Bob » Thu Jan 26, 2012 11:43 pm
Then you've got to insure it, and it may prove worthless if you need to sell.
Not wanting to smother a good idea, but...
