What grade oil in the bongo 2.5TD auto box?
Jimbob738
- Location: Jaaaaacksdale! but a nottingham boy throught and through! you reds
i am changing the oil pan gasket on the gearbox at the weekend going to put fresh oil in the gearbox what grade do i use?
- haydn callow
Re: What grade oil in the bongo 2.5TD auto box?
Remove ...clean..replace the mesh filter and "blow" through the in/out pipes to the rad cooler whilst you are under there.
I think you will need around 5 liters.
Hi, Jimbob i,am about to do mine this weekend.can you let know how you got a new gasket and at wot cost,as most of the experts say just clean up the old one and re-use it.Jimbob738 wrote:i am changing the oil pan gasket on the gearbox at the weekend going to put fresh oil in the gearbox what grade do i use?
Tomo
Tomo 53 wrote:Hi, Jimbob i,am about to do mine this weekend.can you let know how you got a new gasket and at wot cost,as most of the experts say just clean up the old one and re-use it.Jimbob738 wrote:i am changing the oil pan gasket on the gearbox at the weekend going to put fresh oil in the gearbox what grade do i use?but i like to replace joints.
Hi Tomo,
If you give Alacrity a shout he should be able to supply you with a gasker at a resonable price.
Cheers.
dexron 3 is correct, but oil specs have moved on a mile in 15 years.
i use millermatic atf DM, good stuff but expensive, but i will never need to do it again,(unless i get the mileage muz has
Jimbob738
Genuine Mazda Gasket on Fleabay 25 notes im only changing it coz some muppet before me decided to put a silly amount of silicone all the way round the old one now drips oil all over the place doing my head in abit so thought i will change it.
