Replacement rear washer pump
dblake
Post by dblake » Sat Jan 14, 2012 10:38 pm
Just had an MOT failure due to front washers not working. Have ordered a 91-99 MX6 front pump to rectify this.
Last year my rear washer failed but never got round replacing that pump and was wondering if the same MX6 pump is compatible?
Re: Replacement rear washer pump
Post by Simon Jones » Sat Jan 14, 2012 11:06 pm
The electrical connections on front and rear pumps are different, so you want be able to interchange them without modifying the connectors. The front pump has both blades of the contact parallel with each other, while the rear has one at 90 degrees. You'll probably find a rear pump from another Mazda will be compatible.
