If you pull off the centre spark plug cap on the passenger side and look into the plug well you can see a cut out in the casting. If you look through the cut out, there is a cavity which is full of oil (I think). I am fairly certain that it is this fluid that is occasionally overflowing the reservoir and dribbling down the plug well. I think this cavity should be bone dry (as some of the other similar cavities in other plug wells are...).
Does anyone know where this fluid may be coming from and how I would go about fixing it? It's a disaster at the moment as we have about 3000m to do this Xmas which was gonna be in the Bongo....Not happy to take it at the moment. Any suggestions gratefully received......
