Air Con belt
dublin26
Air Con belt
Post by dublin26 » Wed Dec 21, 2011 6:21 pm
Hi, need some advise is it okay to drive my van, 2.5 diesel .... I have been told that it needs a new Air Con Belt as the one on it is frayed and is making the noise l can hear under the engine . It looks as if l will not be able to source one until after Xmas and l just wanted some advise if l can continue driving even if the belt breaks?.
Re: Air Con belt
Post by teenmal » Wed Dec 21, 2011 6:31 pm
dublin26 wrote:Hi, need some advise is it okay to drive my van, 2.5 diesel .... I have been told that it needs a new Air Con Belt as the one on it is frayed and is making the noise l can hear under the engine . It looks as if l will not be able to source one until after Xmas and l just wanted some advise if l can continue driving even if the belt breaks?.
It should be OK,I would personaly remove the frayed belt before it can do any damage.
Cheers.
Re: Air Con belt
Post by g8dhe » Wed Dec 21, 2011 6:33 pm
I would imagine that if the belt breaks then it might cause problems with the water pump & alternator belt see
http://lushprojects.com/bongopartsmk2/c ... o=.html#10
