2 Litre Starting
Posted: Wed Dec 21, 2011 12:11 am
by maxi_77
Our 2 litre Bongo is getting more reluctant to start. The present trick is to turn the switch to start and turn the engine over for a bit until it tries to start, then switch off and repeat, normally it then starts. It is then a bit sluggish until it reaches running temeperature when it behaves fine. Any subsequent starts during the day are fine.
Any suggestions other than buy a diesel Bongo
Re: 2 Litre Starting
Posted: Wed Dec 21, 2011 9:04 pm
by terrybull
Sounds to me like the choke not working. My 2L starts on the first turnover every time, the method I use is to press accelerator once to set the choke then keep off the pedal when turning the key. I did have a starting problem when cold (during summer) but that was a battery issue which I'm sure you've checked.
Posted: Wed Dec 21, 2011 10:35 pm
by francophile1947
terrybull wrote:Sounds to me like the choke not working.
Do they have a choke
Thought they disappeared years ago - pre fuel injection
Posted: Thu Dec 22, 2011 12:26 am
by mikeWalsall
Usually the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
One reason is maybe the temperature sensor is faulty and not sending the right info ..??
Posted: Thu Dec 22, 2011 1:37 pm
by teenmal
It might be worthwhile checking the operation of the choke, and cleaning the choke sensor plug.
PS What country are you in.
Cheers.
Posted: Thu Dec 22, 2011 1:49 pm
by mikeWalsall
Usually injected engines do not have a choke ..the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
Posted: Thu Dec 22, 2011 1:58 pm
by teenmal
mikeWalsall wrote:Usually injected engines do not have a choke ..the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
Hi on these old vehicles it is called the Building Choke.This is the one on a v6.
Posted: Thu Dec 22, 2011 2:21 pm
by mikeWalsall
"The Building Choke" ... on the injection system ..
I must admit it is something I have never heard of.
Posted: Thu Dec 22, 2011 3:39 pm
I must admit I am confused between what looks like a Choke and is called a Throttle (with a Throttle Position Sensor - TPS) on modern engines!
Posted: Fri Dec 23, 2011 11:54 am
by Nevets
mikeWalsall wrote:Usually the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
correct
Posted: Fri Dec 23, 2011 8:41 pm
by maxi_77
Nevets wrote:mikeWalsall wrote:Usually the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
correct
Any hints as to where the temperature sensor is?
Posted: Thu Jun 05, 2014 12:40 pm
by ginger colin
My 2.0 sometimes wanders up from 800rpm to 1200rpm. Then back down. Im looking for the sensor as well.
Posted: Thu Jun 05, 2014 7:11 pm
by mikeWalsall
The sencer numbers are ..18-840c ...... and 18-510 .. dunno where they are situtaed ... I would check around the water pump area ..
http://lushprojects.com/bongopartsmk2/c ... 2of02.html
