is this japanese coolant ??
Posted: Mon Dec 12, 2011 5:55 pm
did a coolant change over the weekend for a member who quite rightly was unsure of what coolant he had in and whether he was adequately protected. the bongo was bought from a dealer forecourt, but not a bongo (specialist).
his thoughts and mine were to drop the coolant and replace certain key parts while the system is down.
the coolant was dropped into a container from the rad drain point, and several key pipes were removed and the internals of the system/rads/matrix's/engine were examined, and the through flows checked,all appeared very good.
on inspection of the dropped coolant it was found to have a 3 inch tall head that a pint of bitter would be proud of, this stood proud and crusty for a good ten minutes
my question is, is this jap coolant?, the reason for this question is really to help others to spot jap coolant, ive bled/changed coolant on a few bongos and have never seen coolant like this.
it was really dark green, but as we know this means nothing
the system was really well flushed and new oat coolant put in, the owner reports several improvements, but these are mostly due to the gen mazda stat and fan switch changes.
anyone with more experience than i know the answer please.
