I'm considering trying a vacuum bleed / purge / fill kit when I do my rad and stat swap. One like
Only trouble (apart from the question will it do a full fill with no air pockets, or will I still need a funnel & bleed pipe type bleed) is that the kit has a 36mm bung, and the Bongo has a 32mm neck in the expansion tank.
So, fellow bongonaughts;
Has anyone out there used a kit like this to fill a Bongo coolant system?
Did it work without further bleeding?
Did it work, but need further bleeding?
How did you get the kit to fit - is there a 'filler neck expander adaptor' available?
Dave
