Fuel Pump problem
wheel2d
Fuel Pump problem
Post by wheel2d » Sat Dec 03, 2011 3:47 pm
We're based in the Highlands and Bongo bits are few and far between -
We've got a Bongo Friendee 2.5TD first registered on 01-12-1998, first UK registered on 23-08-2006. The fuel pump is not working so we sourced a 2nd-hand one but it doesn't seem to fit - can anyone help out ?
We were sent a WL 958 (104745-0043)...according to our mechanic we need the WL04D (10470-0822).
He says that the positioning of the vacuum , the wiring & a couple of other important bits are different to what was sent .........
The engine number is WL419129
and the chassis number is SGL5201063
Any info would great thanks -
A Bongo Newbie
Re: Fuel Pump problem
Post by Northern Bongolow » Sat Dec 03, 2011 7:54 pm
pictures for us thikies may help :) .
Post by Ian » Sun Dec 04, 2011 7:31 pm
The correct part number for the fuel pump to match your series 2 Bongo is WL0413800D.
wheel2d
Post by wheel2d » Mon Dec 05, 2011 12:26 pm
Ian wrote:The correct part number for the fuel pump to match your series 2 Bongo is WL0413800D.
The original pump has a part number zexel104640-0822...... the replacement one has zexel 104645-0042.......
Post by Ian » Mon Dec 05, 2011 12:35 pm
Yes, that's correct. Zexel make the fuel pumps, so the Zexel number of the pump you require is 1046400824. The corresponding Mazda part number is WL0413800D. The corresponding Bosch part number is 9461626008.
The pump you have bought will not fit, although some of the components may be compatible.
wheel2d
Post by wheel2d » Mon Dec 05, 2011 5:34 pm
Ian wrote:Yes, that's correct. Zexel make the fuel pumps, so the Zexel number of the pump you require is 1046400824. The corresponding Mazda part number is WL0413800D. The corresponding Bosch part number is 9461626008.
Thanks for that........
