Air pressure confusion regarding.....
jaylee
Post by jaylee » Sat Nov 26, 2011 10:02 pm
My sofa..?!!! :? :? :?
I have just seen Ady's (Northern Bongolow) fantastic information video. =D> =D> =D> http://www.youtube.com/watch?v=coo15ZovECo
My problem is my wife & i own a futon & i think we may be running a bit low, there is some excess wear on on the outer edges.... (late 90's.?) 8) If Ady could pm me the correct pressure please.... (It's not from DFS or IKEA..!) :wink:
karena
Re: Air pressure confusion regarding.....
Post by karena » Sat Nov 26, 2011 10:44 pm
Ady is busy peeling chell off the ceiling - it was around 220 over 150 when i left - if that helps.
Post by Northern Bongolow » Sat Nov 26, 2011 11:28 pm
you should have seen what she did when i tested the new chainsaw on a fire log----------------in the lounge.
women-----no sense of a bargain that needs to be tested. #-o #-o #-o .
in answer to your question jamie.
a lot depends on whether you require a little (roll together) for a saturday evening :shock: . or are you happy to keep your distance,(i im afraid dont have the option as she says ive done something wrong) but i dont know what #-o .
if you have kids like mine you may need at least 300 psi to enable the little darlings to to bounce off each piece of furniture as they navigate the room.
failing that 100 psi shoul be fine.---------------------------------------------------mate [-X :wink:
karena
Post by karena » Sun Nov 27, 2011 12:00 am
poor little darlings have no choice they cant walk across the floor cos they will get splinters :lol: :lol: :lol:
Post by Northern Bongolow » Sun Nov 27, 2011 12:06 am
[-X [-X :wink:
Post by Doone » Sun Nov 27, 2011 12:27 am
I can understand why you took that indoors Ady, it'll be handy for blowing splinters off the floor. =D>
jaylee
Post by jaylee » Sun Nov 27, 2011 1:31 am
Northern Bongolow wrote:you should have seen what she did when i tested the new chainsaw on a fire log----------------in the lounge.
Need to keep the distance... The wife has flu... :roll: I also believe i have an air lock in an occasional table too? It overheats, even with the aid of a coaster under the coffee mug!! :mrgreen:
