Which 100mm glow plugs ?
droodle
Post by droodle » Fri Nov 25, 2011 8:50 pm
Looking for a set of glow plugs for the bongo .. mechanic ordered 85mm ones and the plate was touching other bits of metal .. so measured the existing ones and they are approx 100mm.
done a quick search on ebay and found several differnt brands .. which if any would you recommend please ?
http://www.ebay.co.uk/sch/i.html?_from= ... Categories
thanks.
Re: Which 100mm glow plugs ?
Post by Northern Bongolow » Fri Nov 25, 2011 9:05 pm
the original spec/manufacturer for bongo electrical stuff is denso, see if you can get denso in the correct length.
you get what you pay for.
