fuel gauge issue
sarahndaz
fuel gauge issue
Post by sarahndaz » Tue Nov 22, 2011 1:27 pm
hi guys
when we bought our 1995 auto diesal there was a bit of insulating tape over the fuel gauge ,and was told that when the needle reaches this point you will run out ,now this hasnt been a problem but i would like to sort it eventually ,any ideas as to the cause of this ,is it a faulty gauge or is it fuel sender problem ,it is between quarter and half when it happens
thanks in advance
Re: fuel gauge issue
Post by francophile1947 » Tue Nov 22, 2011 1:55 pm
Almost certainly a bad tank earth. Loads already on the forum and a factsheet here http://www.igmaynard.co.uk/bongo/member ... sender.pdf
sarahndaz
Post by sarahndaz » Tue Nov 22, 2011 2:57 pm
Thanks very much
wonkanoby
Post by wonkanoby » Tue Nov 22, 2011 3:22 pm
but would a bad earth make it over read
ie say its 1/3 tank when empty???????????
normally its no read at all with the earth
briwy
Post by briwy » Tue Nov 22, 2011 5:10 pm
If you can't get at the floor plate for whatever reason just clean the tank lip down to bare metal round one of the holes in it, bolt/nut through the hole to an eye connected (preferably soldered) onto a length of wire which then goes back to any earth point on the body/chassis.
Check it works OK and then get some underseal or Waxoyl round the bolted connection.
Post by francophile1947 » Tue Nov 22, 2011 9:22 pm
wonkanoby wrote:but would a bad earth make it over read
Yes indeed - I ran out with the gauge showing 1/4 full :oops: :lol:
jaylee
Post by jaylee » Wed Nov 23, 2011 10:05 am
You should be able to test the gauge by unplugging the the two wire white fuel sender connector at the top of the tank with the ignition on, the dial should fall to empty...
Then, by shorting the connector contacts on the connector plug after a minute of 2, the needle should rise & read to full...?!!!
If this happens? The actual gauge should not be the fault...
