Stalling on setting off
al & chris
Post by al & chris » Tue Nov 22, 2011 11:10 am
Just had bongo serviced and had new plugs put in. Now from a cold start in a morning bongo stalls when setting off. Starts fine no smoke etc and will go ok if run for a minute before setting off. All other times starts fine even after several hours at work. It has never done this before, could one of new plugs be fualty. 2.5 TD automatic.
Any ideas
Al
wonkanoby
Re: Stalling on setting off
Post by wonkanoby » Tue Nov 22, 2011 11:19 am
is the cold start working
ie were it over revs for the first few minutes then drops back to regular idle
al & chris
Post by al & chris » Tue Nov 22, 2011 1:34 pm
Thanks think it is that . We had a new rocker cover gasket put on as well. Maybee something is not connected back together properly.
wonkanoby
Post by wonkanoby » Tue Nov 22, 2011 1:41 pm
thats very possible
the solenoid bits work it are to rear of engine on a bracket on drivers side
http://www.igmaynard.co.uk/bongo/forum/ ... +fast+idle
there is a good picture in there black and white bits with wires plugged to them
al & chris
Post by al & chris » Thu Nov 24, 2011 11:59 pm
Strange looks like its cured its self. Not got to look at it yet but all apears to be ok now!
wonkanoby
Post by wonkanoby » Fri Nov 25, 2011 9:35 am
turning on a/c should also cause throttle to pick up and idle to rise
might be enough to eleviate the situation on a temp basis
