starting
starting
got a new annoying problem with my precious,sometimes when i start her up,she just clicks when i turn the key,other times it will start first time no problem at all,have been told that it could be the solenoid,or the ignition barrel,and another person told me that it is an electrical fault but they coul not be any more specific.has anyone else had this problem and if so what is the cure
paul
First thing I'd check before getting too concerned is the connections to the battery. Make sure that they're clean and nice and tight.
When I had my towbar fitted at a garage they'd left the earth lead on very loose. Starting became intermittent (exactly as you'd described) until I checked the earth connection to the battery and found that I could pull it off with one finger [insert smutty inuendo here!]
Well this is great ,
no not the problem I mean the answer cus I have just started to have the same prob on the bongo and was worried I'd be stranded at the horrible school I've been workin in with all the Lauren's and rude boys crowdin round givin me 'looks' !!
I will get Mr S to check the battery immediately he gets in !! Yes, I am that incompetent!
love Salmon x
love Salmon x
starting
my precious is not happy,i have checked battery and connections,their fine but the problem is still there,sometimes she will go all day starting and stoping with no problems at all,but the next day it,s click,click,click and then off she goes like nothing has happened.any ideas.paul
Starting !
Sounds like our minor problem, sometimes it would start first time and then other times it would just click for about 5 or 6 turns.
Replacement Solenoid did the trick never missed a beat since.
Shane
Shane
starting
my starting problem on my precious has been traced to the starter solenoid,i plan to remove it next week and exchange it for reconditioned one,i know that the solenoid is servicable but i feel that replacing it would be better,browsing through the archives i see that the problem can reoccur even after a clean up.paul
