Rear power point
longhaul8
Rear power point
Post by longhaul8 » Wed Nov 16, 2011 4:36 pm
Is there a seperate fuse to the rear power point ? as it has now decided not work took it out fuse on rear is fine but it seems no power at the wires.
Re: Rear power point
Post by g8dhe » Wed Nov 16, 2011 6:13 pm
Its the same fuse as the front one, however some of the sockets do have built in fuses between the connectors on the rear so if the front one is working then check the connectors and see if you can see where the fuse has melted!
The fuse down by the drivers knee is;
longhaul8
Post by longhaul8 » Wed Nov 16, 2011 6:27 pm
Cheers Geoff,
must be a fuse somewere else as the front one works fine i am now thinking it might have been changed due to the fact i have a leisure battery fitted and i dont need the ignition on to use these sockets.
Post by g8dhe » Wed Nov 16, 2011 6:33 pm
Yes if you have a leisure battery fitted that will almost certainly be the case, if the fuse above hasn't been replaced by a wire then you will have to search around, but its normal to switch BOTH to the same source via the same fuse, so I would still check the back of the rear socket and see if you have one of the fused variety. Otherwise its possible that they have also beefed up the wiring to the rear socket and provided it with its own fuse, look at the L/B and follow the wiring back from the +VE terminal you will probably find a fuse box fitted under the bonnet.
longhaul8
Post by longhaul8 » Wed Nov 16, 2011 6:56 pm
yes the power socket has a fuse at the rear and this is fine there is no power from the wires so will look tomorrow think there is a bank of fuses behind my glove box so i will go looking when i have some light.
