Roof stuck open? How to lower it.
Some topics come up again and again. Here you will find short cuts to frequently asked questions, mainly of a technical nature.
Post by Doone » Thu Dec 22, 2011 12:56 am
Just in case the free top roof on your Bongo jams in the open position, carry an emergency roof lowering kit in the Bongo.
This is simply a 4mm Allen key and a strong cord, 6 metres long and 4mm diameter.
You may like to print the instructions on how to use these to lower the roof. They're on THIS LINK
A word of caution, do make certain the roof is really stuck before you do anything else - press the control switch in the roof, check the handbrake is on, and check the handbrake switch.
