Help needed with leisure battery
miraz
Post by miraz » Sun Nov 13, 2011 11:46 pm
Hi all! We have full conversion with fridge which runs from 13A socket or from 12v ciggie socket from leisure battery but this socket doesn't work! Is there a fuse between the lb and the 12v socket that I can check? Hope this makes sense! Cheers everyone :D
1995 2.5tdi 2wd Herts
Re: Help needed with leisure battery
Post by Simon Jones » Mon Nov 14, 2011 12:15 am
Probably, but do you have any more details about type of conversion is fitted?
Jezza
Post by Jezza » Mon Nov 14, 2011 11:07 am
you'll need to trace the wiring from the leisure Battery to find the (new) fuse box for the items connected to it
It will all depend on if the conversion is a home-brew job, or professional job - if it was done by a company (and you know who it is) a quick google, and phone call should give you the info you need - if it's a home-brew job it could be a lot more fun
Jezza
