Page 1 of 2
				Space saver tyre
				Posted: Thu Nov 10, 2011 5:39 pm
				by TerryG
				Is it possible to get a 'new' Bongo space saver, maybe from another Mazda model? Mine looks OK and holds pressure, but after 15 years exposed to the elements.....well, it doesn't exactly inspire trust so I also carry a tyre repair aerosol.
				Re: Space saver tyre
				Posted: Thu Nov 10, 2011 5:54 pm
				by slow_n_low
				Why dont you carry a normal size tyre as a spare ?
				Posted: Thu Nov 10, 2011 6:49 pm
				by daveblueozzie
				Dump the spacesaver and get a full size tyre and wheel.
				Posted: Thu Nov 10, 2011 7:42 pm
				by Diplomat
				daveblueozzie wrote:Dump the spacesaver and get a full size tyre and wheel.
I decided not to dump the spacesaver when I realised that I couldn't back the 215 tyres onto my ramps.
If you are doing something like the exhaust, it is worth popping the space saver on to get it up on the ramp and have a bit more room to work.
Just don't use it as a spare. Get something that matches whatever tyres you have on the front. Keep the spacesaver in the shed.
Frank
				Posted: Thu Nov 10, 2011 8:16 pm
				by nicstrike
				Diplomat wrote:daveblueozzie wrote:Dump the spacesaver and get a full size tyre and wheel.
Frank
 wider ramps ,or a jack & stands (which you would need to change the spare anyway)?
				Posted: Thu Nov 10, 2011 9:19 pm
				by mikeWalsall
				That's what I did .. picked up some wider / taller Transit van type of ramps from a car boot sale for £10
				Posted: Thu Nov 10, 2011 9:36 pm
				by Diplomat
				Must admit I haven't actually used it for that yet.
Perhaps it's the hoarder's justification: "It will come in useful some day"!
Frank
				Posted: Thu Nov 10, 2011 9:48 pm
				by mikeWalsall
				I still have my Space saver ..  the tyre must be over 12 years old yet it is still (looks) to be porous / crack free ..
Using the spare wheel space for the LPG tank .. I kept the Space saver .. as full size spare wheel takes up a lot of 'boot space' ...
How do you drive up a pair of 'narrow' ramps ... with only one Space saver wheel fitted .. surly that would 'twist' the chassis / body ??
I remember years ago a mate jacked up his Austin Allegro (Allagro) using a 'wrong' jacking point ... and the windscreen popped out ..!!
				Posted: Thu Nov 10, 2011 10:17 pm
				by francophile1947
				mikeWalsall wrote:I still have my Space saver ..  the tyre must be over 12 years old yet it is still (looks) to be porous / crack free ..
So did mine until I tried to inflate it - the valve had hardened and snapped off when I tried to attach the pump
				Posted: Fri Nov 11, 2011 12:06 am
				by Bob
				I'd guess a trawl of the tyre suppliers might turn up a skinny, they probably fit something else.
				Posted: Fri Nov 11, 2011 10:28 am
				by TerryG
Does a full size tyre/wheel fit in the same place as the space saver then? I wasn't aware of that.
				Posted: Fri Nov 11, 2011 10:43 am
				by borntobag
				sure does, I have a 235/50/18 as my full size spare, fits in nice and snugg.
				Posted: Fri Nov 11, 2011 11:01 am
				by daveblueozzie
				Its a no brainer really
  12 to 16 year old skinny tyre on a 2 ton bongo
 , accident waiting to happen if you have to use the skinny
				Posted: Fri Nov 11, 2011 11:17 am
				by MountainGoat
				The skinny is a get you to the nearest garage tyre not a get you home/continue your journey tyre. Its recommended limitations according to Mazda are 50 miles at a maximum speed of 50mph. A bit awkward if you have a puncure on a Sunday or miles from anywhere.
Tony
				Posted: Fri Nov 11, 2011 12:01 pm
				by TerryG
				borntobag wrote:sure does, I have a 235/50/18 as my full size spare, fits in nice and snugg.
Excellent! Thanks for that.
Does make one wonder why Mazda put a skinny under there in the first place.
