Space saver tyre
TerryG
Space saver tyre
Post by TerryG » Thu Nov 10, 2011 5:39 pm
Is it possible to get a 'new' Bongo space saver, maybe from another Mazda model? Mine looks OK and holds pressure, but after 15 years exposed to the elements.....well, it doesn't exactly inspire trust so I also carry a tyre repair aerosol.
'Enjoy every sandwich'
slow_n_low
Re: Space saver tyre
Post by slow_n_low » Thu Nov 10, 2011 5:54 pm
Why dont you carry a normal size tyre as a spare ?
daveblueozzie
Post by daveblueozzie » Thu Nov 10, 2011 6:49 pm
Dump the spacesaver and get a full size tyre and wheel.
Lost without my Bongo.
Diplomat
Post by Diplomat » Thu Nov 10, 2011 7:42 pm
daveblueozzie wrote:Dump the spacesaver and get a full size tyre and wheel.
I decided not to dump the spacesaver when I realised that I couldn't back the 215 tyres onto my ramps.
If you are doing something like the exhaust, it is worth popping the space saver on to get it up on the ramp and have a bit more room to work.
Just don't use it as a spare. Get something that matches whatever tyres you have on the front. Keep the spacesaver in the shed.
Frank
They flew, I took up naturism
nicstrike
Post by nicstrike » Thu Nov 10, 2011 8:16 pm
Frank
wider ramps ,or a jack & stands (which you would need to change the spare anyway)?
mikeWalsall
Post by mikeWalsall » Thu Nov 10, 2011 9:19 pm
That's what I did .. picked up some wider / taller Transit van type of ramps from a car boot sale for £10
Diplomat
Post by Diplomat » Thu Nov 10, 2011 9:36 pm
Must admit I haven't actually used it for that yet.
Perhaps it's the hoarder's justification: "It will come in useful some day"!
Frank
mikeWalsall
Post by mikeWalsall » Thu Nov 10, 2011 9:48 pm
I still have my Space saver .. the tyre must be over 12 years old yet it is still (looks) to be porous / crack free ..
Using the spare wheel space for the LPG tank .. I kept the Space saver .. as full size spare wheel takes up a lot of 'boot space' ...
How do you drive up a pair of 'narrow' ramps ... with only one Space saver wheel fitted .. surly that would 'twist' the chassis / body ??
I remember years ago a mate jacked up his Austin Allegro (Allagro) using a 'wrong' jacking point ... and the windscreen popped out ..!!
Post by francophile1947 » Thu Nov 10, 2011 10:17 pm
mikeWalsall wrote:I still have my Space saver .. the tyre must be over 12 years old yet it is still (looks) to be porous / crack free ..
So did mine until I tried to inflate it - the valve had hardened and snapped off when I tried to attach the pump :lol: :lol:
Post by Bob » Fri Nov 11, 2011 12:06 am
I'd guess a trawl of the tyre suppliers might turn up a skinny, they probably fit something else.
8)
TerryG
Post by TerryG » Fri Nov 11, 2011 10:28 am
Does a full size tyre/wheel fit in the same place as the space saver then? I wasn't aware of that.
borntobag
Post by borntobag » Fri Nov 11, 2011 10:43 am
sure does, I have a 235/50/18 as my full size spare, fits in nice and snugg.
daveblueozzie
Post by daveblueozzie » Fri Nov 11, 2011 11:01 am
Its a no brainer really #-o 12 to 16 year old skinny tyre on a 2 ton bongo :shock: , accident waiting to happen if you have to use the skinny [-X .
MountainGoat
Post by MountainGoat » Fri Nov 11, 2011 11:17 am
The skinny is a get you to the nearest garage tyre not a get you home/continue your journey tyre. Its recommended limitations according to Mazda are 50 miles at a maximum speed of 50mph. A bit awkward if you have a puncure on a Sunday or miles from anywhere.
Tony
TerryG
Post by TerryG » Fri Nov 11, 2011 12:01 pm
borntobag wrote:sure does, I have a 235/50/18 as my full size spare, fits in nice and snugg.
Excellent! Thanks for that.
Does make one wonder why Mazda put a skinny under there in the first place.
