Sorting out the heater isn't a problem as I've done one before but the space that the heater normally occupies is taken up by all this stuff.
OK, so the bits on the left are for the winter valve on the exhaust, not needed so they've all gone which leaves the stuff on the right which obviously controls the turbo wastegate as the pipe from the wastegate actuator leads down here. (the one on the left with the white dot)
All this stuff can be taken off the brackets and relocated if necessary making sure it's away from the exhaust and the Eberspacher.
What I really need to know is, is all this definitely required to control the turbo properly? I have taken the wastegate feed pipe and connected it directly to the vacuum pipe and the engine starts/runs OK.
What I don't know is , will the ECU throw a wobbler without all this gubbins attached and will it effect performance/mpg? What does the gubbins actually do given that the engine runs OK without it?
I'm reluctant to take it out for a run in case it damages something.
On our last (earlier 95) Bongo the wastegate pipe disappeared down the side of the engine. I assume it was connected directly to the vacuum pipe. Lush diagrams don't show where the pipe is connected to.
Incidentally, has anyone taken this thing off? It's some sort of water heater for the EGR by the looks of it. Given that I've blanked off the EGR it not doing anything so I want to get rid to make access to the turbo/exhaust better.
Problem is that the bleed tube comes from it
whereas on a "normal" Bongo it comes from the head. Anyone know where I could get the T piece that is one the head as on ours there is only one hose leading down to the turbo.
Thanks for any help/info.
