Rear window washer
Rear window washer
Hi folks..looking for some help here.. How do I remove/replace the rear window washer jet on my Bongo ?
- Driver+Passengers
Re: Rear window washer
These diagrams may help, they may not...Bongolitus wrote:Hi folks..looking for some help here.. How do I remove/replace the rear window washer jet on my Bongo ?
Matt
- Driver+Passengers
Just went to have a look at mine. Don't know if it's the same but...
Open the tailgate and there should be an inline connector in the section of pipe visible between body and tailgate. Remove this and activate rear washer to confirm your getting water through. If so, try clearing out the nozzle with a pin (and then keep the pin pushed into your driver/passenger sun visor incase you ever need it again. You may already be at this point.
If you definitely need to remove the nozzle, then remove the grommet in the tailgate (just prise it out). I'm assuming the nozzle itself is held in by a similar grommet. I don't know if you'd need to take the spoiler off or not - looks like there's a bit of clearance, but not a lot.
Thanks Bongolier..The hose has come away from the back of the jet..wasn't too sure wether to just pull the nozzle out of the rubber mount or not !
- Driver+Passengers
I can't see any other way, myself.Bongolitus wrote:Thanks Bongolier..The hose has come away from the back of the jet..wasn't too sure wether to just pull the nozzle out of the rubber mount or not !
