Blinds
Observer
Blinds
Post by Observer » Sun Oct 23, 2011 1:27 pm
Sorry if it has been covered before, but my rear drivers side blind has stuck in the 'up' position. I can hear the motor whiring when I press it's switch but no movement. There was meant to be a video posted sometime ago on how to dismantle the job but if I remember right, it did not work (Photobucket)
Any help would be great
My iPhone - My office
Bongopoet
Re: Blinds
Post by Bongopoet » Sun Oct 23, 2011 4:19 pm
Have you tried pulling it down by hand?
Observer
Re: Blinds
Post by Observer » Mon Oct 24, 2011 9:12 am
Yes, and quite firmly but it won't budge and afraid I might wreck it alltogether. The others work by hand or switch BTW
jaylee
Re: Blinds
Post by jaylee » Mon Oct 24, 2011 9:33 am
Might be worth a try by just removing the lower panel, (From the window ledge down.) & see if anything could be fowling the mechanism..? http://lushprojects.com/bongopartsmk2/c ... 1of02.html
Is it the rear most blind on the drivers side?
Observer
Re: Blinds
Post by Observer » Mon Oct 24, 2011 10:36 am
Yes that's the one
jaylee
Re: Blinds
Post by jaylee » Mon Oct 24, 2011 1:25 pm
[quote="Observer"I can hear the motor whiring when I press it's switch but no movement. [/quote]
Observer wrote:Yes, and quite firmly but it won't budge and afraid I might wreck it alltogether. The others work by hand or switch BTW
Observer wrote:Is it the rear most blind on the drivers side?
Yes that's the one
Normally with mine anything obstructing the blind, (for instance a bag at high level against the window stopping it going down?) just stops the motor...
I'm wondering if your tracking is warped, say like closing the parallel distance in some where & the drive from the motor has come adrift too??
Have you had any work done in that area, like a conversion?? :-k
I'm just guessing... I never had any mechanical problems to deal with on my blinds..
Observer
Re: Blinds
Post by Observer » Mon Oct 24, 2011 3:26 pm
So far. I've removed the bottom panel and the corner section of the top, I can see the bottom curved part of the channel/frame. I can't see anything stuck in the track either at the sides or bottom and although I do have a conversion, the units are designed to be taken out. The track is still parrallell (by eye) and I sometimes do/have stored things on the worktop upright beneath the blind's travel area which might have forced a cog out of line.
I supose the motor is behind the upper trim panel and that looks like I will need to remove the grab handle to get a peep. At least I wll be able to re-site the switches at the same time. Thanks for the exploded view where are all these stored?
Re: Blinds
Post by g8dhe » Mon Oct 24, 2011 4:16 pm
The exploded diagrams originate from Mazdazip.ru but an easier to use version is here http://www.lushprojects.com/bongopartsmk2/
Observer
Re: Blinds
Post by Observer » Mon Oct 24, 2011 4:28 pm
Now book marked for the future
Observer
Re: Blinds
Post by Observer » Tue Oct 25, 2011 3:38 pm
Does anyone know if I should continue as above or not? I thought I might have been able to see how the the thing works at this stage.
Is it run by an endless belt or cord (inside the grooved frame) so that it pushes the blind up or down? I could never understand how it is possible to be able to raise or lower by hand or switch without breaking something :!:
jaylee
Re: Blinds
Post by jaylee » Tue Oct 25, 2011 3:58 pm
From memory, the motor is at the bottom centre on all three blinds except the one over the door which is at the top..
The spring in the roller that helps it retract may have jammed it at the top though..? I think it is sprung at the top??
dave_aber
Re: Blinds
Post by dave_aber » Tue Oct 25, 2011 4:03 pm
^ That's the page you need on the lushprojects site.
It's a pair of mini-teleflex cables, which run from the motor (Bottom centre on 3 blinds, top centre on the sliding door one) around to the attachment points at the bottom of the blind cloth.
If you can't move it by hand either, then one of the cables must have jammed somehow, or the motor / gearing has jammed. I guess the best bet is to get a replacement blind & frame complete with motor from a breaker.
To remove the top trim panel you do need to remove the grab handle.
You can just see the motor on the front offside blind in this photo, it's behind the bracket with the barcode sticker on it.
Image...Image
Observer
Re: Blinds
Post by Observer » Sun Oct 30, 2011 11:13 am
dave_aber wrote:http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Thanks for all help so far.
It's been some time . . . . After removing the rest of the trim etc the complete blind frame came away easily. Four tiny screws holding a clamping plate allowed the motor housing to come free and then I was then able to move the blind by hand.
Out of the side of the motor was a bevel gear/pinion which drives a tiny plastic/nylon rack back and forth. This gear was very corroded and there was debris in the track. A spritz of WD and a sharp skewer cleaned up the pinion and I then wiped out the track and reconnected the cable and it worked \:D/ Just a matter of getting the trim back now.
On a different tack, I haven't decided which R&R bed to buy as yet and before I put it all back, I was wondering is it possible/legal? to completeley remove the seat belts and reuse them attached to the bed for when it is used as a seat?
Re: Blinds
Post by g8dhe » Sun Oct 30, 2011 1:26 pm
On our conversion, with R&R bed/seat, the nearside belt remains in its normal position, the offside belt top mount is repositioned on the support for the conversion a square section 1" tube floor to ceiling, the winder is mounted on the R&R frame, the clips for both then pop up thru a hole on the R&R bed top surface in the middle of the seat and are bolted to the centre bar of the R&R frame.
Observer
Re: Blinds
Post by Observer » Sun Oct 30, 2011 2:21 pm
g8dhe wrote:On our conversion, with R&R bed/seat, the nearside belt remains in its normal position, the offside belt top mount is repositioned on the support for the conversion a square section 1" tube floor to ceiling, the winder is mounted on the R&R frame, the clips for both then pop up thru a hole on the R&R bed top surface in the middle of the seat and are bolted to the centre bar of the R&R frame.
Good, I'll take out the offside kit then - I suppose a bed company like http://www.jdsmetaltech.co.uk/index.html will know just how to fix it to the bed.
