First post on here, so Hi first of all!! I am having a niggling issue with my Bongo and I'm hoping you guys can shed some light on it. The Bongo starts first time, every time with out any issues. If you immediately drive off it is fine. However, if after starting, it sits ticking over for say 15 seconds or more it starts to 'chug' a little bit with the result of black / grey smoke coming out the rear. This issue quickly disappears with a few revs of the engine or even if it is left to it's own it will clear itself and then run fine for the rest of the day. This issue only happens in the morning, for the rest of the day it is fine and as I say, it starts first time every time.
The Bongo is fully serviced (regulary) and the fuel / air filters were replaced in the last service 2 weeks ago, plus glow plugs were checked and found to fine.
Any tips / advice would be greatly received.
Cheers,
Andy
