Changing rear aircon matrix
Posted: Mon Oct 03, 2011 11:21 am
Hi All,
I have a replacement rear aircon matrix to fit as the old one has a leak- In order to fit it I have to undo the aircon pipes but I'm a bit worried about checking the system for remaining pressure. The aircon doesnt work as the level is too low (despite a refill 2 months ago
) and when I press the pintle down in the refill point (the one marked "H") I get very little gas coming out - is it safe to undo the matrix connections? I would have thought so but just wanted to check if anyone had done this themselves.
Next time around I'll use a decent garage that does a pressure check before a refill!
cheers,
Steve
cheers,
Steve
