roof
runner10_6
roof
Post by runner10_6 » Sun Oct 02, 2011 4:17 pm
Help, just put the roof up, and when brought the roof back down the passanger side didn't!! the roof has now twisted and cracked and will not close fully. Any ideas for help my number is 07799840503. I live in Bingley west yorkshire.
Andrew
Re: roof
Post by missfixit70 » Sun Oct 02, 2011 4:24 pm
There's a few threads/links here that may help - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=51017
wormey
Re: roof
Post by wormey » Sun Oct 02, 2011 8:34 pm
I'd check the roof hinges, motors etc. If it was mine I'd put the roof up and check the workings very carefully. The link Miss fixit is a good one.
Hope you get it sorted.
Daz
Daz and debs
runner10_6
Re: roof
Post by runner10_6 » Tue Oct 04, 2011 10:36 am
Checked roof and the motor has come loose off the mounting at passenger side and all the cable workings have been drawn through the motors hence when i lowered the roof it twisted as one side only powererd up and cracked the roof.got the roof down but had to disconect all runners etc so no the roof is not locked down and is still beeping.Any help would be gratefull.
fredasurf
Re: roof
Post by fredasurf » Tue Oct 04, 2011 2:39 pm
not wanting to alarm you but that happened to ours too, we managed to get it fixed with just WD40 on the side that got stuck but eventually had to buy a new roof from scrap to replace the cracked one. You can't fix it, we tried boat repairers, caravan places and all sorts. Sorry.
runner10_6
Re: roof
Post by runner10_6 » Thu Oct 06, 2011 3:13 pm
Hi, thanks for the info i have taken it for repair hopefully to get it working and resecure the motor by mounting the motor all the way through the roof and recable it up.Hopefully the cracked roof with be repairable as it is at the side and i have been told it is in a none stessed area.
many thanks.
P.S everybody check the mortor mounts securely and that the plastic motor mounts have not give way with age of the old plastic.
runner10_6
Re: roof
Post by runner10_6 » Thu Oct 06, 2011 3:31 pm
Hi,just had a call to say that all the roof is back working and mounted trough the roof etc i just need to repair the cracked roof now
the guy that fixed it was Adrian at machester campers at bury it seems that he is a good guy
many thanks
