Really?Speedo converter to convert your Mazda Bongo from KPH to MPH. The converter also delimits the engine which will give you extra top end.
From here - http://www.mazdabongoshop.co.uk/Shop/Miscellaneous.html
Seems unlikely to me, as the older diesel engine doesn't have an ECU (don't know about the newer onesmissfixit70 wrote:Really?Speedo converter to convert your Mazda Bongo from KPH to MPH. The converter also delimits the engine which will give you extra top end.
Will gearbox ECU give extra top end power? - it usually requires an engine ECU.mikeWalsall wrote:Strange ... I would have thought even the Bongo Diesels auto box would have an electronic control unit / sensors that takes pulses from the cars speedo ..
Absolutely right i've had one !!mikeWalsall wrote:As well as from crappy auto fluid .. 'Temperamental' gearbox changes have been attributed to having a speedo converter chip for the MPH / Mileometer on some Japanese motors
Hey, & if one was fitted..?!!mikeWalsall wrote:My observations where more to do with running problems than it being a 'super performance chip' ..
