Hissing sound !!
sub123
Hissing sound !!
Post by sub123 » Tue Sep 20, 2011 2:37 pm
Hi All,
Just driven home from town (only about 20 mins) and noticed a hissing sound whilst driving. after getting home and switching the engine off it was still hissing. It is coming from under the drivers side and is the pipe circled red in the picture. After a few minutes it got quieter then sounded like it was bubbling..? It was definitely something to do with this pipe as when I felt it I could feel the bubbling sound (if that makes sense!).. It was also very hot.
Can anyone shed any light??
Ta.
widdowson2008
Re: Hissing sound !!
Post by widdowson2008 » Tue Sep 20, 2011 2:41 pm
That's the top hose - to radiator.
Have you checked the coolant level in the expansion tank??
Don't drive it until problem identified and FIXED.
Steve
jaylee
Post by jaylee » Tue Sep 20, 2011 2:51 pm
Yer not talking about the thin vacuum hose running over the top hose are you??
Its just that, when my top hose went there, there was rather alot of steam which came out from under the drivers door when stationary....
The vacuum hose however can split where it attaches to the nipple on that metal elbow where the inter cooler pipe comes up..?
Just covering all possibilities..!!
sub123
Post by sub123 » Tue Sep 20, 2011 2:55 pm
No... Definitely the fat hose. And looks like the coolant level is very low / non existant!
Should I fill with water to see if it leaks anywhere?
jaylee
Post by jaylee » Tue Sep 20, 2011 3:04 pm
I would be looking at bleeding the system.. You may have got an airlock..? :idea: :arrow:
Post by missfixit70 » Tue Sep 20, 2011 3:15 pm
DO NOT drive it anywhere until you have at least refilled & bled it properly, preferably find& fix the leak/problem first though.
Post by haydn callow » Tue Sep 20, 2011 4:07 pm
Get that hose replaced and the system refilled and bled by someone who has done a BONGO before....see you tube vid's and bleeding instructions..
Defo DO NOT DRIVE IT (even a few hundred yards)
sub123
Post by sub123 » Tue Sep 20, 2011 5:12 pm
I've topped it up with water to see if I can see if it's leaking. There seems to be drips coming out from underneath (about an arms length from under the drivers seat).
Gonna make some calls tomorrow.
Post by haydn callow » Tue Sep 20, 2011 5:20 pm
could well be the water pump
M 80NGO
Post by M 80NGO » Tue Sep 20, 2011 9:10 pm
You have andys imports just down the A47, give him a ring for advise on bleeding the system :wink:
http://www.google.co.uk/url?sa=t&source ... 6T5a-Kn09g
Post by mikeonb4c » Wed Sep 21, 2011 1:11 pm
...and since no-one (including Haydn, the supplier, who has shown remarkable restraint) has said it yet:
Please fit a low coolant alarm.
With luck, you have got away with it this time. But next time, it could be a v. big bill :(
PS - I have no commercial interest whatsoever with this product, but I was one of the first to buy and fit one, and its arguably the best bangs per buck investment I've made in the Bongo. Yer can't cost out peace of mind. 8)
sub123
Post by sub123 » Wed Sep 21, 2011 4:12 pm
So It's a split top hose on the drivers side. split at the other end at the the joint (so the bloke at my local garage told me!)
Do I need one of these?
http://www.bongobits.com/Main.asp?PageN ... roduct=234
and where would i get a low coolant alarm?
[Insert shameless plug here]
sub123
Post by sub123 » Wed Sep 21, 2011 4:18 pm
Looking at the schematic, I'm not sure if its actually 15-186 or 15-183 ???
aarggh!!
widdowson2008
Post by widdowson2008 » Wed Sep 21, 2011 4:41 pm
15-186
Don't forget 2 new clips (9WNCB-3700B)
Steve
sub123
Post by sub123 » Wed Sep 21, 2011 6:11 pm
Great picture! Yep it's the 15-186.
Ta
