Whats wrong with my bongo?
Please help, after driving for about 10 minutes the bongo feels like its going to cut out when slowing to a stop, although never does. With the clutch in the drive position it also shudders forward and wont remain stationary when stopped. Anyone any ideas?
Re: Whats wrong with my bongo?
Sounds to me like the clutch is not fully disengaging/dragging so it is either worn or you need to bleed the air out of the clutch hydraulics(inspect the clutch slave cylinder for leaks)
or take it to a clutch garage or bongo specialist garage is required
put in your location and a local member may advise..
Hope this helps cheers Steve.
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
I'm confused (as usualGump wrote:Please help, after driving for about 10 minutes the bongo feels like its going to cut out when slowing to a stop, although never does. With the clutch in the drive position it also shudders forward and wont remain stationary when stopped. Anyone any ideas?
Thanks for the reply, its an automatic
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
first thing is to check the oil level, to little or to much can be fatal, maybe it just needs the gearbox oil changing for some nice new stuff, it may also be worth getting the Throttle position sensor set up correctly its only a 2 minuite job,
Where are you located maybe a local bongolier could give it a look over for ya, but get it sorted soon before you do some real damage, and keep us posted.
