I lucked out and got 20x DS18B20 sensors on eBay for around 18p each - they're normally over a quid each. These are Dallas 1-wire digital sensors (probably just a thermocouple internally), with the advantage being that I should be able to hook up as many as I like without using up all my ADC pins - just one digital pin for the lot. They also have a built-in alarm function with upper and lower thresholds which, while not necessary, make the coding easier.
Here's my setup (note: only 1 wire to read them all)...
Yes - I've lost one already!
Sample rate is probably <1 second for the lot. The idea is to cable them up, epoxy the ICs into small lengths of s/steel tubes and run them around the van - the normal hose locations, as well as internal/external ambient, air duct, blah blah. Basically, no restrictions other than routing them to the right places. They're not supposed to be deployed in a star topology as performance may degrade due to signal reflections, etc... but that's easily solved by running one or more busses (use a couple more pins... whatever!)
Lots more plans for the 'duino, but temperature sensing is first. (Mod: feel free to move this thread to "Pimp my Bongo" if it starts getting out of hand
