Hi chaps
I fitted a chrome bar to the from to my Bongo last year and now feel the need for a bit more bling! How difficult is it to mount (and more to the point - connect) additional lights? The bar has mounting points for lights so it almost seems rude not to....
My technical skills struggle to cope with modern Lego...
Many thanks
Tim
Extra lights on front bar?
Moderator: Ian
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Re: Extra lights on front bar?
its fairly easy to be honest, i assume that you want lights that come on with high beam which will need a relay to operate them safely, due to the location of the lights to the location of the engine bay it makes this easy to do, there are also angel ring lights available where the angel ring lights with the side lights and the main beam is hooked via a relay to the main beam curcuit.
personally i think the bongo looks more modern with just the bars and no lights
http://www.ebay.co.uk/itm/TWIN-12v-CAR- ... 66729dbfef
If you go for a set of spots on top of the bullbar...Stick with 6" lights... Some 7"s will interfere with the dipped headlight lower beams...
