MOT runs out next week..........
dave_aber
Post by dave_aber » Thu Sep 01, 2011 7:45 am
So I went in yesterday, and got it done early (just in case) and it passed!
Another year ahead then :D
One advisory - very slight play in the n/s track rod end.
More importantly, since I went to a garage where I know the owner, I got that invaluable look around underneath on a proper ramp.
So, I now know that one of the transmission cooler hoses I disturbed doing the ATF change is weeping and needs a new clip, and - more worryingly - I have a very slight coolant weep from the n/s end of the rad where the bottom hose connects. Looks like I will be learning how to bleed a Bongo fairly soon! Not sure yet until I get a good look at the rad if it's just the hose clip or the rad itself.
Image...Image
Driver+Passengers
Re: MOT runs out next week..........
Post by Driver+Passengers » Thu Sep 01, 2011 8:07 am
Result! Have fun fixing.
Image Image
Post by Northern Bongolow » Thu Sep 01, 2011 11:38 am
sounds a strange position for a leak on the coolant system dave,they dont usually leak on the coolest,least used hose.
check its not leaking above and tracking around.
dave_aber
Post by dave_aber » Thu Sep 01, 2011 6:04 pm
Went in and had a look. It's certainly a minor weep rather than a leak as such. So, all cleaned off and I'll check it again after a run and see what's what. It might even be spilled screenwash
Before Cleaning:
After:
Whilst I was down there, I dropped off the intercooler shroud for a better look, which means dropping the intercooler since there's a scrivet top centre holding them together. The bottom 3 rows were well impacted with grit and unfortunate insects. Cleaning that lot out and un-folding the vanes led to some sections coming away, but no harm done. Also flushed the cooler body out, got a wee bit of oily stuff but not much at all.
Before:
After:
Image...Image
Post by Northern Bongolow » Fri Sep 02, 2011 4:21 am
my mrs bongo has had a niggly little leak since last winters low temps,ive ripped the entire front off it twice now,finally found it. it was a tiny leak from one of the screen wash bottle motors,the frost had loosened the bottom seal round the bottom edge of the motor, it looks like a permenant push fit seal to the motor body,compared with the other one it had a very slightly larger gap.a nice dollop of 2 part epoxy and it was sorted.
maybe worth a look.
the picture looks ok to me, there isnt much that can go wrong with the plastic stub, as there is no reaction under the hose/clip like there could be under a metal stub.
