Stopping key in ignition beeps
Mickymouse
Post by Mickymouse » Sun Aug 28, 2011 3:21 pm
Hi All
I read the tip about stopping the beeps when the ignition key is inserted and a door open.
But after removing the three screws in the cowling under the steering wheel I found that it was attached to the top piece and therefore could not be removed!
I have looked in Lush Projects and it is shown as two seperate bits.I am loathe to use brute force to try and seperate the two halves.
Any ideas?
Mick
White 1996 P.reg SGL3 2.5D AFT Side Conversion
brorabongo
Re: Stopping key in ignition beeps
Post by brorabongo » Sun Aug 28, 2011 3:30 pm
ボンゴの激怒 pictures
Post by g8dhe » Sun Aug 28, 2011 5:49 pm
You don't need to remove the entire cowling at all, just the grey flap underneath (two screws) to reach the area, its tight but you will see the little white plug/socket which needs to be separated.
jaylee
Post by jaylee » Sun Aug 28, 2011 10:42 pm
Mickymouse wrote:Hi All
Any ideas?
Mick
If you should need to remove the cowl? Lower/drop the steering wheel, tighten the wheel angle latch again, grab the top of the hole where the stalks for the indicator & wipers are, then give a yank up! It will come apart...
Mickymouse
Post by Mickymouse » Wed Aug 31, 2011 12:09 pm
Thanks for all your advice.
I have now done the job,no beeps with key in! :D
Found it much easier to do by removing the cowling first.
Thanks again
Mick
