				Diesel 4x4 auto air-con tensioner question
				Posted: Wed Aug 24, 2011 4:01 pm
				by def_fid
				Just completed a round trip of Scandinavia, 4280 miles in 3 weeks. Nothing went wrong. Used 200ml of oil. Averaged 28mpg.
  However the alternator belts needed adjustment and the aircon belt is chirping under load. Should I replace the tensioner wheel when I replace the aircon belt, or does it just need a bit of oil?http
				Re: Diesel 4x4 auto air-con tensioner question
				Posted: Wed Aug 24, 2011 5:12 pm
				by missfixit70
				Probably just needs the pulleys deglazing & new belts, as long as all the pulley bearings are ok.
				Posted: Wed Aug 24, 2011 6:07 pm
				by Kincaid
				missfixit70 wrote:Probably just needs the pulleys deglazing & new belts, as long as all the pulley bearings are ok.
Hi - to test the bearings do you need to remove the belts - or just drop the tension on them?
