Thermostat Housing
Thermostat Housing
Post by Ian » Mon Aug 15, 2011 4:04 pm
Shortly my ace mechanic (Northern Bongolow) will be replacing my thermostat. But the thermostat housing will need replacing because it is seized and will need to be dismantled. NB has the replacement housing, but needs to get hold of the "paper" gasket and has asked me to track one down. So I need the part number. I have had a look on lush projects (page 1500C) but can't spot it.
http://www.lushprojects.com/bongopartsm ... mgno=.html
Can anyone help us out?
wonkanoby
Re: Thermostat Housing
Post by wonkanoby » Mon Aug 15, 2011 4:08 pm
do you mean 15 165
Post by g8dhe » Mon Aug 15, 2011 4:11 pm
Are you a V6 or diesel, Ian these days ?
The V6 shows a gasket here 15-173 http://lushprojects.com/bongopartsmk2/c ... f02.html#9
Post by Ian » Mon Aug 15, 2011 4:13 pm
That shows as the waterpump inlet gasket. Is this the same thing?
Post by missfixit70 » Mon Aug 15, 2011 4:16 pm
Looks like it to me, just wrongly described :wink:
Post by missfixit70 » Mon Aug 15, 2011 4:17 pm
g8dhe wrote:Are you a V6 or diesel, Ian these days ?
Diesel :wink:
widdowson2008
Post by widdowson2008 » Mon Aug 15, 2011 4:28 pm
If it's Diesel
15-165 on diagram as wonkanoby says.
if V6
Geof's right 15-165 shows as stat cover gasket. What ya looking at?
Steve
Post by missfixit70 » Mon Aug 15, 2011 4:43 pm
widdowson2008 wrote:If it's Diesel
if V6
You mean 15-173 for the V6? :wink:
But it's the diesel one for which the part no is WL0115165 (drawing no 15-165) "Gasket w.pump inlet" http://www.lushprojects.com/bongopartsm ... no=.html#8
widdowson2008
Post by widdowson2008 » Mon Aug 15, 2011 6:22 pm
if V6
Sorry Kirsty - YES I did. Bloody good job you're there to correct errors. :lol: Thanks. =D>
Note to self: Stop 'cut & paste' - too easy to drop a b******..
Diesel bit was almost right though :lol:
Steve
Post by g8dhe » Mon Aug 15, 2011 6:26 pm
On the V6 the same gasket is used in at least two places, one on the thermostat and one on the water outlet of the water pump - however they both point to the same description look at the gasket behind part 15-17Z (water outlet) and the gasket behind 15-176B (thermostat).
But its irrelevant as Ian has obviously got rid of his V6!
