I have noticed that there are two 20mm holes, one on each wheel arch leading into the bottom of the sills. Should these have bungs in them or are they meant to ventilate the sill?
Are they there as standard or would they have been drilled for rust treatment?
Holes
Holes
Re: Holes
if your talking about the rear arch ones, they should have a grommet in.
Re: Holes
Yes, the rear ones, I will find some blind grommets, and spray some ACF 50 in there for good measure. I think mine have probably been pinched or fallen out because I would have noticed them sooner than this when washing the arches.Northern Bongolow wrote:if your talking about the rear arch ones, they should have a grommet in.
Re: Holes
I had a proper look underneath yesterday and there are a couple more missing on the inner part of the sills. The ones that are present look like Scrivets. I squirted some ACF 50 in there for good measure.Velocette wrote:Yes, the rear ones, I will find some blind grommets, and spray some ACF 50 in there for good measure. I think mine have probably been pinched or fallen out because I would have noticed them sooner than this when washing the arches.Northern Bongolow wrote:if your talking about the rear arch ones, they should have a grommet in.
