Rear Electric blinds
jason
Post by jason » Sat Aug 06, 2011 10:51 am
Hello
I have just recently got a bongo (2.5 v6 2002) and the rear blinds do not work. Any ideas?.
Jason #-o
Re: Rear Electric blinds
Post by g8dhe » Sat Aug 06, 2011 10:59 am
Welcome to the forum.
Try operating the switch on the dashboard a few times, the switch doesn't get used much and the contacts oxidise. After that check the fuses
Post by missfixit70 » Sat Aug 06, 2011 11:31 am
Check the rear switches too, if they have been disconnected I don't think the blinds will work from either switch. May need the switches dismantling & cleaning, I'm sure Jaylee'll be along soon :wink:
westonwarrior
Post by westonwarrior » Sat Aug 06, 2011 11:44 am
You can still use them manualy for now
jaylee
Post by jaylee » Sat Aug 06, 2011 12:31 pm
missfixit70 wrote:Check the rear switches too, if they have been disconnected I don't think the blinds will work from either switch. May need the switches dismantling & cleaning, I'm sure Jaylee'll be along soon :wink:
Can't really elaborate on what you just said Kirsty... But normally after a few presses at the front gets em going even if there is a little delay...? Cleaning the internal contacts makes em responsive "like new"!!
Have you had a leisure battery removed Jason, or a fuse gone leading from one!?? :-k
